Water leak at 'A' pillar - VW Eos Forum : Volkswagen Eos Forums
Reply
Thread Tools Display Modes
Old 11-02-2013, 11:00 AM   #1
A.J.
Senior Member
A.J.'s Avatar
Default Water leak at 'A' pillar
I have a water leak that drips from the top of the 'A' pillar on the passenger side. I have Krytox'd the sun roof seals twice in the last 2 months but the leak still persists. As it forecast to rain heavily last night I left a towel on the seat to protect the seat, the towel was damp this morning.
When I opened the roof, full opening not just the sun roof, to try and establish just where the water is getting in a fair amount came out of what I assume is a drainage pipe that locates in the top of the 'A' pillar.
The nozzle at the end of the roof strut was quite dry in terms of oiling. I have now given them both a good dose of Krytox oil.
What bothers me is why hadn't the water drained down the 'A' pillar anyway. Is there an issue with the drainage in the 'A' pillar, can this get blocked on occasions, seems unlikely as it is only pure water that passes down the drainage system.
How can I check this or even better if it is blocked, how can I clear it if it is the problem ??
A.J. is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-02-2013, 09:17 PM   #2
silvershadow
Ageing Revhead/Moderator
Default
This problem has been covered extensively on this forum and the rectification has been described in detail with photographs - I am travelling interstate at the moment and do not have the opportunity to find the relevant posts however I suggest you use the SEARCH facility on the forum with "water leaks" as the key words and you will find the solution.
__________________
Carer for my partner's Eos 2.0 TDI DSG MY09 Australian specification - Candy White/Cornsilk Beige leather trim. Her 12 year old grand-daughter has now staked a claim for future ownership when my partner is no longer capable of driving .
Old 11-02-2013, 10:57 PM   #3
MrT
Senior Member
MrT's Avatar
Default
This should help http://www.vweosclub.com/forums/showthread.php?t=2138
MrT is offline   Reply With Quote
Old 11-03-2013, 06:44 AM   #4
silvershadow
Default
Quote:
Originally Posted by MrT View Post
Thanks MrT .
__________________
Old 11-03-2013, 08:40 AM   #5
MrT
Senior Member
MrT's Avatar
Default
Np :-)
Old 11-03-2013, 09:22 AM   #6
A.J.
Senior Member
A.J.'s Avatar
Thumbs down
Thanks for the link. I did look at that but it all looked a little alien to me, I couldn't see any that resembled the tube shown.
You will have to bear with me on this as I am not at all mechanically minded. However I have just looked again and there doesn't appear to an easy way of accessing the end of anything within the 'A' pillar.
My impression is that it would appear to be a blockage rather than something that has come adrift and subsequently leaking.
I assume this wouldn't be an expensive repair by a VW dealer albeit an inconvenience.
Old 11-04-2013, 08:54 PM   #7
A.J.
Senior Member
A.J.'s Avatar
Default
Rained heavily last night, again !, and no leaks !! .
Not going to get too exited though as it is only the one night.
Rain forecast for to-morrow so we will see if I have cracked it or not.
Old 07-11-2014, 02:30 PM   #8
StuM
Junior Member
Default
I've got the same problem on my 57 plate EOS. Only happens during really wet weather and almost always just on the passenger side. Only thing is that I'm having a similar problem to A.J. getting access to the drain tube that appear to be the perpetrator - I've seen the link above so know how to fix it when I get in there but does anyone have any guidance to get access to it?
StuM is offline   Reply With Quote
Old 07-11-2014, 02:40 PM   #9
StuM
Junior Member
Default
Posted the above message to quickly, just found this:
http://www.vweosclub.com/forums/showthread.php?t=7602
Lets see how I get on...
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
