I Just fitted cruise control 20! - Page 2 - VW Eos Forum : Volkswagen Eos Forums
Reply
Thread Tools Display Modes
Old 06-12-2016, 09:26 AM   #26
Uncle David
Junior Member
Default Added Cruise Control
Yep....another one. Just added it this morning. I used a genuine VW cruise control kit for my 2008 EOS TDI Auto. The car has MFD and steering wheel controls plus paddles. I only used the kit since I spotted it on fleabay and it was GBP 55.00 which I thought was rather a bargain. Comes with detailed instructions, tie wraps, the special wire with terminations (I didn't need) plus retrofit stickers in several languages.
Overall, with Voxmagna's post above and the video link, (Many thanks!) I managed to do it in a little over two hours.(mainly due to faffing about finding tools). The airbag is a bit awkward to get off and I think I may well look into bending a flat blade screwdriver in the future (as per the video) It's easy to scratch your instrument cluster plastic if you're not careful. Coding took a couple of attempts as I initially selected the wrong code. Anyhow, job done and works a treat! Happy days!
For reference above, mine doesn't show the speed set in the MFD either.
Uncle David is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-12-2016, 01:46 PM   #27
voxmagna
Senior Member
Default
It makes a difference having it, especially on all those roadworks stretches with speedcams.
Now I have cruise as factory fitted from new on another VAG I'm curious about the way my Chinese clone works in MY07 EOS.
MY07 EOS puts on the green cruise symbol showing it is active as soon as I slide the stalk switch across to 'on'. I tend to leave it active all the time and the cruise symbol is always on in my MFD.
However, our later VAG factory fitted cruise only puts the cruise light on when you push the stalk button to activate it, even though the slide switch is always set for cruise 'on'. It's not something I'm that bothered about and may be something in the clone stalk firmware.
What happens with your cruise switch and the green cruise symbol?
Old 06-12-2016, 02:09 PM   #28
Andy tsi eos
Senior Member
Default
Hi there
My light only comes on after I set the speed.
Mines a genuine vag one reto fitted by a main dealer.
Hth
__________________
2.0 TDI Sport 2007.5. Black with red leather. Cruise Control. Wind Deflector. RNS310 GPS Radio running Version 7 maps. Warning Triangle. Mtec cross drilled front discs. Hankook K120 tyres all round. Fully refurbished Solitude 17" alloys. LED licence plate lights. LED side lights.
Andy tsi eos is offline   Reply With Quote
Old 06-12-2016, 02:49 PM   #29
scratchedeos
Senior Member
Default
In Australia cruise control was standard. In my 2007 model when you turn on the Cruise with the switch on the top of the lever the light turns on. When it is actually enabled there are no light changes. In our MK VI Golf 2011 - it has the white lighting on the instruments not the red, the light in the dash only comes on when the cruise is finally activated. The speed that was last set is shown at the bottom of the MFD.
__________________
ScratchedEos
2007 2.0TDI 6 speed Manual Paprika Black Leather, Sat Nav,18's and Xenons Western Australia
scratchedeos is offline   Reply With Quote
Old 06-12-2016, 09:43 PM   #30
voxmagna
Senior Member
Default
Thanks. That makes me think the difference in logic was either changed in the early/later ECU firmware or the instrument module and not the stalks. My other VAG which works like your Golf is a 2012. I don't think I want to go messing with firmware updates for either unless they go wrong.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
