Volkswagen Eos Rear Bumper Reinforcer - VW Eos Forum : Volkswagen Eos Forums
Go Back   VW Eos Forum : Volkswagen Eos Forums > VW Eos Owners Community > For Sale & Group Buys
Reply
Thread Tools Display Modes
Old 10-06-2015, 04:34 PM   #1
brsince78
Member
brsince78's Avatar
Default Volkswagen Eos Rear Bumper Reinforcer
Part number: VW0361672
Fitted to my 2009 model until replaced recently to allow a tow hook to be fitted.
Slight surface rusting on one side.
Buyer collects in South East Wales / Bristol area.
Price new is approx 50..... please make a sensible offer.
brsince78 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-09-2015, 03:19 PM   #2
voxmagna
Senior Member
Default
Which way did you go on the tow bar install? OEM new bumper and paint, or cut the old one? Which tow bar & ball kit? Any photos?
Old 10-09-2015, 06:11 PM   #3
brsince78
Member
brsince78's Avatar
Default
* OEM new bumper reinforcer
* Original rear outer bumper panel cut (which worried me initially but it is not too noticeable and saved me megabucks in not buying a new part)
* Detachable Westfalia removable towbar, professionally fitted (by PF Jones)
http://www.pfjones.co.uk/eos-2006-de...le-towbar.html
Attached is the only photo I've got available at the moment.
The car is pretty clever. When I have the towbar fitted and engage reverse gear the rear parking sensors are de-activated and a towbar graphic appears on the lcd screen in place of the normal 'radar chart'.
Fully recommend PF Jones.... very professional fit and no problems since.
File Type: jpg 10411015_945548525471582_2567635864191651051_n.jpg (146.8 KB, 16 views)
Old 10-09-2015, 08:11 PM   #4
voxmagna
Senior Member
Default
Thanks that is exactly the way I was thinking of going. What put me off was the seemingly enormous cut out required in the bumper for both ball and power socket. But then I worked out for occasional trailing if you didn't mind the trailer power socket tucked up behind the bumper you could use a smaller cutout just for the locking ball. Yes they fitted the CANbus controller which links into the OE electronics to disable the parking sensors and put up the trail light on the dash.- Thanks a lot.
Old 10-10-2015, 04:32 PM   #5
brsince78
Member
brsince78's Avatar
Default
The power socket swings through an arc so you can tuck it up out of the way when not in use and bring into line with the cut when you need it. When I was sizing up the job the replacement outer bumper with the removable face-plate was by far the most expensive item. I thought I'd have the cut done and see if I could live with it. It is really not that noticeable.
Old 10-10-2015, 06:49 PM   #6
voxmagna
Senior Member
Default
It's not just the replacement bumper but getting it painted as well. I estimated around 800 excluding the bar kit!
The OE replacement bumper has a box molded in behind the cutout to stow the electric socket (s), but I thought you could live without that, which is what you did - Thanks for coming back.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
