drivers door blown in wind - VW Eos Forum : Volkswagen Eos Forums
Reply
Thread Tools Display Modes
Old 02-18-2016, 02:14 PM   #1
busy
Junior Member
Default drivers door blown in wind
well bugger. parked up opened the door and boom wind took it.. I grabbed the interior handle only to have it remain in my hand. now door wont shut and I cant see why. It closes when you lift but theres no clunking when its lifted.. I wonder is there a shear pin or something inside that needs replacing. any help appreciated
busy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-19-2016, 10:55 AM   #2
Batjes
Senior Member
Batjes's Avatar
Default
It sounds like you really do need something changed. But it is difficult to say what just on your words. Could you take pictures about the door hinges? And of course other visible damag...
Batjes is offline   Reply With Quote
Old 02-19-2016, 12:22 PM   #3
paulg
2012 EOS Highline
Default
Just a guess... but
check the bottom part of the door. There's a piece that inserts into the door sill. That could be out of line and thats why the door only closes when you lift.
__________________
2012 EOS Highline, Technology Package, Black on Black with Vienna Leather
paulg is offline   Reply With Quote
Old 02-19-2016, 02:45 PM   #4
voxmagna
Senior Member
Default
I think it might be worth talking to a body repair shop first. A door is a door, but how true now is the vertical section carrying the hinges? You need to worry about getting the door to sit square against the frame seal, all the shut gaps correct and more important, the top glass edge sitting perfectly against the roof seal. If it doesn't you will get tonnes of water coming off the roof spilling inside.
I always worry about 2 door cars because they present a very large surface area to wind. Normally you would expect the metal restraint strap to hold the door, but once a door starts opening with wind behind it, there is a heavy mass to stop. Did your restraint stay together or break?
That metal stub at the bottom of the door is for side impact protection and is a substantial piece of steel. If that doesn't align with the slot in the cill your hinges or the vertical support pillar are probably out of true.
Old 02-22-2016, 03:33 PM   #5
busy
Junior Member
Default
Well Thanks for replies, I managed to have a look for the first time today, no obvious damage so got the Mrs to lift up on door handle and it all became apparent, Hard to see but managed to see the pin in the top hinge was over further and moved back when she lifted the door this needed 2 people as I couldnt see doing it by myself. literally a few mm on the hinge and door wont close. Have to buy a whole new hinge as pin is not available, I will try to see if the pin is transferable as the new hinge needs painting and report back.
Old 02-22-2016, 03:37 PM   #6
busy
Junior Member
Default
forgot to say paint and hinge less than 30 and Voxmagna, there is no strap on my eos doors
Old 05-19-2016, 09:04 AM   #7
voxmagna
Senior Member
Exclamation Agree, no restraints on the EOS doors.
I compared MY07 EOS doors with our cheap Skoda. As you say there is no metal folding restraining strap, which is unusual for large heavy doors on a 2 door car.
I think your bad experience is a warning to everybody that a strong gust of wind on a part open EOS door can force it open and cause damage. Another potential safety issue is whilst parked on the emergency hard shoulder on a windy day when lorries are whizzing past should you open the driver door.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
