Shwoop-shwoop sound - VW Eos Forum : Volkswagen Eos Forums
Reply
Thread Tools Display Modes
Old 10-14-2016, 10:11 PM   #1
Compt1ga
Junior Member
Default Shwoop-shwoop sound
Hi friends. My 2008 EOS is making a shwoop-shwoop-shwoop sound. It sounds like it's coming from the accessory drive end of the engine. The warmer the car is the louder it gets. The car is at the dealership and they haven't figured it out yet.
I look forward to your thoughts.
Compt1ga is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-15-2016, 07:57 AM   #2
Batjes
Senior Member
Batjes's Avatar
Default
When is it doing that? Whilst steady driving speed? Or accelerating? Is it worse taking corners? Alse when driving in reverse?
It could be wheel bearing or worn brake or something like that...
__________________
2.0 tfsi dsg
Batjes is offline   Reply With Quote
Old 10-18-2016, 06:52 PM   #3
Compt1ga
Junior Member
Default Shwoop-Scwoop Sound
I hear it best when sitting still. It seems to speed up with engine RPMs. When I'm moving the road noise drowns it out.
Old 10-19-2016, 05:09 PM   #4
Batjes
Senior Member
Batjes's Avatar
Default
So it is engine only related. That could be components like waterpump, generator, engine itself. How many miles did it run? Is it due to an belt change? I assume it is not clutch related... Those are the things to look into.
__________________
2.0 tfsi dsg
Old 11-06-2016, 08:53 PM   #5
Compt1ga
Junior Member
Default
Sorry for the long delay in following up. The dealership could not determine the source of the sound. It is definitely from the engine. I suspect that it is belt drive related due to the speed at which it occurs. Anything else would happen at a much shorter interval. I'm going to put a mark on the belt and see if it seems to go by at the same interval as the sound
Old 11-06-2016, 08:59 PM   #6
voxmagna
Senior Member
Default
The best tool to investigate with is a mechanics stethoscope. Car engines can produce noises from different directions which bounces off hard surfaces making it difficult to locate them. First try a short length of plastic drainage pipe (30-50mm) on your ear to focus the sound, then listen to various parts with the stethoscope. Hope it's not coming from an important belt like a cam belt or the water pump.
Sponsored Links
Advertisement
Reply
Tags
engine noise
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
