Replacing fog light bulbs ? - VW Eos Forum : Volkswagen Eos Forums
Reply
Thread Tools Display Modes
Old 02-08-2010, 11:54 PM   #1
Darren
Rated EE: Eos Enthusiast
Darren's Avatar
Default Replacing fog light bulbs ?
The owner's manual seems unhelpful in educating us how to replace headlight bulbs or fog light bulbs. I just looked underneath the car and it doesn't look as easy as I'd hoped to replace fog light bulbs. Has anyone done this? Anyone have a link to some schematic on how to approach?
__________________
2011 Eos Lux 2.0T Reflex Silver with Red leather; Nav; Tech package; Spa Wheels; Dynaudio; 3M Clearshield; Smart-top; APR-93 tune
2016 Audi Q5 Premium 2.0T
Monsoon Grey Metallic with Chestnut Brown Leather and APR-93 tune
1970 Volkswagen Karmann-Ghia Pastel Blue with Black/grey interior
Previously owned from 12/2007-1/2011 a 2008 Eos Lux 2.0T Thunder Blue with Moonrock grey leather, Dynaudio, Smart-top and APR-93 tune.
Darren is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-09-2010, 12:23 AM   #2
tortoise
Senior Member
tortoise's Avatar
Default
Quote:
pry out the cover, it looks tight but easily off if u try.
remove the fog light via 3 bolts, and once u have access to it, simple twist out the bulb to change
tortoise is offline   Reply With Quote
Old 02-09-2010, 10:38 AM   #3
Darren
Darren's Avatar
Default
I saw on a GTI that there is a nice place from which to pry.....I see only a tiny little circle opening on the black part of the cover. What do you use to get in there? How hard do you pull?????
__________________
Old 02-10-2010, 02:09 AM   #4
YVR
Junior Member
YVR's Avatar
Default Fog Light Lamp Replacement
Good evening Darren,
See if the following 3 JPEG's are of a help to you.
Rgds, YVR
YVR is offline   Reply With Quote
Old 02-10-2010, 10:48 AM   #5
Darren
Darren's Avatar
Default
Rgds, YVR
YVR-- THANK YOU!!!! PERFECT!
Do you have similar photos for headlamp and high beam bulb replacement (though I suspect they are inherently easier)???
__________________
Old 02-10-2010, 11:24 PM   #6
tortoise
Senior Member
tortoise's Avatar
Default
headlights are a more difficult task, easiest way out is to remove the front bumper and get the headlamps out. else, u can try from the engine bay (ensure the engine is cold, else u gonna have a hard time avoiding the parts from getting burnt)
u need to remove the breather tank on the other side cos it'll obstruct u tho. and use a small mirror to see whats in the connection and avoid 'straining' any other wires
Old 02-10-2010, 11:26 PM   #7
tortoise
Senior Member
tortoise's Avatar
Default
u can use a tool similar to the one that removes the wheel nuts, pull from the hole, initial tightness is there (cos its a virgin - joking kekeke) but it'll come off quite easily
the backing is one piece, the fog lamp surround connects to it.
Old 02-11-2010, 06:31 AM   #8
Odie
Senior Member
Odie's Avatar
Default
Main and dipped beam bulb change is pretty easy (depending on your idea of awkward - being an aircraft techie my awkwardness threshold is set pretty high ), just twist off the covers from the back of the headlight units in the engine bay, then twist the relevant holder to release it from the rear of the headlight unit and pull the bulb out the holder. Careful when fitting the new bulbs you don't touch the glass.
__________________
Regards,
John
'10 VW Eos SE 2.0TDI in Salsa Red tuned to 170 bhp and 280 lbf.ft by Superchips and fitted with the red "I" to suit. Cruise Control retro-fitted by Hazzy Dayz. Also with 17" Le Mans Wheels, Titanium Black Vienna Leather Upholstery, RCD510 Stereo, Chrome Boot Lid Trim, Wind Deflector, Mud Flaps, Osram Nightbreaker Headlight Bulbs, Philips Silver Vision Front Indicator Bulbs.
'99 Honda VFR800Fi in Italian Red.
Odie is offline   Reply With Quote
Old 02-11-2010, 01:43 PM   #9
tortoise
Senior Member
tortoise's Avatar
Default
Quote:
its easier for halogen bulbs, more tricky for the xenon ones
Old 03-07-2010, 01:29 PM   #10
EOSNINA
Junior Member
Default
Unbelievable. Last time I changed my fog lights... I jacked up car. took off tire and got to them from underneath through skid plate and wheelwell LOL
You just saved me about 30 minutes of hell. THANKS MAN
EOSNINA is offline   Reply With Quote
Old 07-09-2010, 10:00 PM   #11
EOSmezera
Junior Member
Default
I actually replaced the whole assembly and saved $250 based on a quote from the dealer. You can buy the exact OEM part on line for $48. Many thanks for the pdf's. You saved me big time!!!
EOSmezera is offline   Reply With Quote
Old 09-18-2011, 08:49 AM   #12
popeye 270
Junior Member
Default
YVR THANKS i was pulling my hair out trying to change my fog light one site told me i had to remove the front grill!!!!!
popeye 270 is offline   Reply With Quote
Old 10-16-2011, 10:29 AM   #13
Darren
Darren's Avatar
Default
I finally got to changing out my fog light bulbs. I'd had bulbs I bought for my 2008 Eos but the car was traded in before I replaced the bulbs.
The pictures above were perfect. I agree that it took a bit more force than I'd planned to remove the trim panel but it was easy. I replaced the standard Sylvania 9006 bulbs with Philips Xtreme Power 9006 bulbs.
__________________
Old 02-10-2013, 03:18 PM   #14
Lopaka
Senior Member
Lopaka's Avatar
Send a message via ICQ to Lopaka
Thumbs up
Many thanks Guys!
I was going to drop the pan and go from behind. I never would have figured it out. I repealed headlights and fogs with Phillips Crystal Vision Ultras. Wow, look like Xenons with a blue white light. Night driving so much easier to see and really gives the car an updated look. I also put chrome handles, mirror caps and grill inserts. Bling! Looks like an Audi even more!
I think the EOS original design is best. The updated look is very generic and bland. Oh, Amazon.com is the way to go! Everything so much cheaper than trying to find it locally here in Hawaii!
Mahalo,
Lopaka
__________________
2008 VW Komfort EOS, Candy White, Beige interior, 2.0T, DSG, all ava. options for this model in US.
Lopaka is offline   Reply With Quote
Old 02-27-2013, 11:11 PM   #15
MrGadget
Junior Member
Default
YVR and tortoise, thank you, thank you and thank you.
This is why I love forums,
It took me all of 20 mins to replace it once I knew how. And the parts guy said he's selling the fog lights all the time because of rocks like the one that knocked out mine.
MrGadget is offline   Reply With Quote
Old 10-19-2013, 01:47 AM   #16
Miami_Lou
Junior Member
Smile Fog lights easy,easy, easy
Rgds, YVR
Thank you so much, this saved me a lot of time it took me less than 10 mins. Make sure to have torx bit to remove housing, I think it was a T25. I thought I was going to have to remove the plate under the front to get to it. But it was so much easier. Use the pull tool that is used for removing the center piece from the wheels.
A big thanks!!
Miami_Lou is offline   Reply With Quote
Old 12-17-2013, 11:28 AM   #17
Atl
Member
Default
Quote:
Originally Posted by Miami_Lou View Post
Thank you so much...
Yes, thank you for a great thread guys!
Just as an FYI, if anyone needs to check their horns for any reason, they're located behind he same plastic foglight panels. There's a horn on each side (well, on my 2008 there is).
__________________
2008 2.0T Lux
I like taking things a p a r t .
Atl is offline   Reply With Quote
Old 01-31-2014, 05:25 PM   #18
David Paul
Senior Member
David Paul's Avatar
Default
Quote:
Originally Posted by russellperry View Post
The foglight bulbs are simple to replace once you move the plastic underbody panels. It's held on by screws on the bottom of the bumper cover. It took me about 15 min to do it the first time.
The bottom pan does NOT have to be dropped.
Before you decide to change your fogs again, I suggest you read (probably for the first time) this entire thread starting from the beginning.
__________________
Photo Albums
2013 CC Sport Plus
Old 07-31-2014, 03:59 PM   #19
AJC
Junior Member
Default
hey guys, 2008 Eos here. Thought i would throw my two cents in: i just replaced my front two headlight (beams) and took some pics.
Like Odie said, it is a pretty easy fix: all you have to do it locate the housing assembly, lift the silver latch towards the hood and off pops the hatch to the housing. From there you need to give the light a quarter turn (counter clock-wise I believe) and the light bulb is exposed. Note I had some issues actually getting the bulb out of the wiring base, so i gently popped it out using a flat head screw driver (picture a male end of a plug). Once complete i did the other (they recommend doing both at the same time).
NOTE: Make sure your engine is cool AND the headlights are cool. I made that mistake when changing the second bulb. Also, wear latex gloves when changing them so you fingerprints dont burn into the bulb.
Lastly, i went with Philips Extreme H7 (H7XVB2 to be exact) bulbs. They ran about $60. So far so good! they are much brighter than the original bulbs, that's for sure!
http://www.vweosclub.com/forums/album.php?albumid=457
AJC is offline   Reply With Quote
Old 01-21-2015, 05:28 PM   #20
ArizonaKid
Junior Member
Default 2012 Eos Fog Light Panel Removal
How do you remove the fog light panel on a 2012 Eos. The pics and descriptions in this thread are for older model years. Thanks in advance.
ArizonaKid is offline   Reply With Quote
Old 01-21-2015, 08:11 PM   #21
voxmagna
Senior Member
Default
As long as you accept the lower bulb life and higher cost of changing them more often!
You cannot get something for nothing with automotive lamps. If you stick with tungsten halogen and want brighter lamps, it is an easy fix to drop in some xenon gas and raise the filament temperature (overun!) but you will be paying out and replacing bulbs more often. Personally I don't want to spend my time changing bulbs when it is inconvenient or risk getting stopped for a non-working lamp. It is not just the $60 either, because if local laws require you to travel with spare lamps, you will need to buy some more of these.
The only way you can get real brightness with lower power, heat and longer lamp hours is Xenon HID or led in oem designed lamp units.
Old 02-20-2015, 03:00 PM   #22
Airforcejohn
Junior Member
Default
2012 Eos, non-HID headlamp assembly. Hi everyone, I need your help directing me to a video or a page out of a service manual. I'm trying to upgrade my headlamps, DRL and fog light bulbs. I think I figured out how to get the fog light black panel off, but I still need your advice on how to take it off without breaking the clips. And I've searched and searched on the Internet on how to get at the low beam halogen light bulbs. The manual simply tells us to take the car to the VW dealer. Do I have to lower the front bumper to access the headlamp assembly? Can I get at the head light bulbs and the DRL bulbs from the removed wheel wells? Help! I would really appreciate your help. John
Airforcejohn is offline   Reply With Quote
Old 02-20-2015, 03:43 PM   #23
voxmagna
Senior Member
Default
When I went about replacing my washer pump, the shop procedure said remove the front plastic wheel linings, the front grill AND the one piece plastic front below the grill (the front of the car!).
The inner arch linings and front grill were easy, but I couldn't quite get the front (bumper) off as there are some molded plastic tags at the top and I never did find out how to release them.
I did notice in the headlamp section they were giving the same 'front of the car removal' procedure so I wish you luck. I must say though, if you can figure out their locking clips at the top which you can't easily see, removing the front gives a lot more working space. But breaking them could be very expensive for a new replacement front body panel and re-paint.
I am waiting for somebody to go further than I did on the front removal and post back how the locking clips are released - You could be the one!
Old 07-08-2015, 05:25 PM   #24
cymro
Member
Default
Hi All,
I realise that this thread's old now, but hopefully I might get some info
looking at the pics on YVR's post, (reproduced below ) it looks very easy to pry off the cover, I'm a little dubious to pull off the central red cover ( see pic) for fear of breaking it. Any advice would be gratefully received.
I'm wanting to remove the black foglight cover to cut a hole to fit drill's.
Thanks....pete
cymro is offline   Reply With Quote
Old 07-08-2015, 07:41 PM   #25
cymro
Member
Default
that last line should have been d r l as in daylight running lights! good ol' auto correct!
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
