215/60R16 fit? - VW Eos Forum : Volkswagen Eos Forums
Go Back   VW Eos Forum : Volkswagen Eos Forums > Volkswagen Eos Forum > VW Eos Tech Q&A > Tires & Wheels
Old 10-20-2016, 04:06 PM   #1
SCUBATDI
Default 215/60R16 fit?
I have a line on some 215/60R16 winter tires on original VW 16x6.5 alloys. I'm currently running 235/40R18 3-season tires. The winter tire combo have a 2.98% larger diameter or 0.76"/19.2mm. So half that for the radial difference. It looks like there will be enough room in the wheel wells, and 3% is within most recommendations.
Does anyone have experience with larger diameter tires on their Eos?
2009 Eos DSG - "Celeste"
2010 Touareg TDI - "Sophie"
2002 Golf TDI - "Simone"
SCUBATDI is offline   Reply With Quote
Old 10-25-2016, 04:22 AM   #2
1texansfan1
Texans fan
I don't have experience- there is a winter tire mode in settings on mine. I would always check to see if speddo was correct. I have the app Torque- which does a pretty good job.
2014 Eros 2.0T Candy White w beige interior. Sunshine mobile.
2014 Passat TDI Long trip cruiser.
1texansfan1 is offline   Reply With Quote
Old 10-31-2016, 01:20 PM   #3
SCUBATDI
Just to close off this thread, the 215/60R16's went on yesterday. Clearance of both brake shields and wheel wells seem good. No rubbing so far. Ride is much more pliable with an extra 2" of rubber. This should be a better ride on our rough winter roads.
1texansfan1: winter tire mode does nothing more than warn you if you go over whatever speed you've set. There are no other changes to the driving characteristics of the car when this mode is on. I've yet to see a dedicated winter tire with a low enough max speed limit to even need to set the warning. Perhaps studded tires may have a lower speed rating.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
