Eos Roof Adjustment. - VW Eos Forum : Volkswagen Eos Forums
Go Back   VW Eos Forum : Volkswagen Eos Forums > Volkswagen Eos Forum > VW Eos Q&A
Reply
Thread Tools Display Modes
Old 10-27-2010, 08:30 AM   #1
Barry C.
Barry C-All
Default Eos Roof Adjustment.
Hi there,
Has anybody out there got any instructions or info on how and where to adjust the Eos roof? Mine is now a year old, and I feel that it may have bedded in, and may benefit from a tweak maybe. It doesnt leak, but I occasionally get the odd rattle.
Thanks, Barry C.
Barry C. is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-27-2010, 11:38 AM   #2
McEos
Member
Default
Quote:
Originally Posted by Barry C. View Post
Hi there,
Thanks, Barry C.
I would not try to DIY the EOS roof adjustment in larger scale, when changing parts to my roof dealer told me that there are over 36 adjustment points and to make sure everything is 100% they need to be checked in sequense as many adjustment points affect others.
I have tweaked the side flaps a bit to cancel some rattles as they were a bit loose when closed. For that there are a screw on the underside of each flap.
McEos is offline   Reply With Quote
Old 10-27-2010, 10:11 PM   #3
silvershadow
Ageing Revhead/Moderator
Default
Hi there,
Thanks, Barry C.
Before considering anything to do with your roof; make sure your Krytox applications have been done every 6 months preferably in warm weather/heated garage to keep the seals supple.
Many roof noises are associated with seals that have hardened due to lack of regular maintenance.
__________________
Carer for my partner's Eos 2.0 TDI DSG MY09 Australian specification - Candy White/Cornsilk Beige leather trim. Her 11 year old grand-daughter has now staked a claim for future ownership when my partner is no longer capable of driving .
Old 10-28-2010, 10:11 PM   #4
Eos_Up
Senior Member
Eos_Up's Avatar
Default
Granted, I keep my Eos in my garage when not using it. I've had it for just about 3 years now and it only has 15000 miles on the clock.
I've NEVER done the famous seal maintenance and it has no top rattles, nor leaks that I know off. I'm up in the Seattle area and have been in occasional heavy rain without a drop coming in from the roof area.
Maybe I've just been lucky...
__________________
2008 2.0L Lux, Eismeer Blue, cornsilk beige
Eos_Up is offline   Reply With Quote
Old 10-30-2010, 06:57 AM   #5
Barry C.
Barry C-All
Default
Hi there,
Thanks, silvershadow,I krytox about every 3-4 months, and that does stop various noises, but I wondered if the thing beds or settles in, and may benefit from a subtle adjustment somewhere,
Regards, Barry.
Old 10-30-2010, 10:08 PM   #6
silvershadow
Default
Hi there,
Regards, Barry.
My partner's car is still quiet after 2 years of use on our poor quality country roads - if there were going to be problems, the regular torture the car gets from potholes and uneven surfaces would make them obvious.
__________________
Old 12-21-2010, 06:31 AM   #7
Bernie
Junior Member
Default Roof Rattles - More Information Please
To McEos,
what 'tweak' did you do to your EOS?
Mine bangs at the C Section over bumps. I have seen all sorts of suggestions from removing shims to putting felt in the locator bracket.
Someone also mentioned a VW Tech Bulletin on this issue, but I've had no luck so far in locating it.
HELP Please
Bernie is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
