How to tell when your dsg transmission is defective - Page 2 - VW Eos Forum : Volkswagen Eos Forums
Go Back   VW Eos Forum : Volkswagen Eos Forums > Volkswagen Eos Forum > VW Eos Tech Q&A > Engine & Drivetrain
Reply
Thread Tools Display Modes
Old 05-30-2018, 09:50 AM   #26
mickjane2
Senior Member
mickjane2's Avatar
Default
Quote:
Originally Posted by voxmagna View Post
Transmission problems like this are not good when you have no warranty. Even with warranty it should not be relied on for serious transmission problems. What to do? Dealer repairs with no warranty will cost plenty. IMHO I would see if there is an independent DSG specialist who can help, at least confirm why they fail to make sure any replacement part isn't going to have the same problem. If V.W give100k miles warranty on their replacement units you can suspect they have changed or fixed something? You may be able to get your unit repaired or replaced with a repaired (upgraded/modified) unit. - but you won't get that from a V.W stealer I guess trying to transplant a used stick change unit would be too complicated?
AFAIK VW donít supply any spares for their DSG boxes other than mechatronic units, clutch kits, DMF,s, and service items. Luckily most DSG,s are very reliable on the whole, itís usually the mechatronic unit which fails first as the rubber solenoid seals harden with age. The early 1.4 engines fitted with the 7 speed wet clutch had problems with clutch pack shims failing, that was sorted by 2013?.
Mick
__________________
2010 Deep Black Pearl SE 2.0 tdi dsg xenons Full electric black leather seats Folding mirrors with chrome covers 18x8j alloys front fogs, Door projector lenses LED footwell lights OEM RNS 510 + bluetooth and Media interface, OEM front and rear mud flaps Sport pedals and dead pedal LED mirror puddle lights and front side lights 35mm lowered springs LED rear number plate lamps.
2018 Tiguan 2.0 TSI DSG SEL Deep Black Pearl.
First EOS 2008 Silver 2.0 FSI DSG sport.
mickjane2 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-14-2018, 04:27 PM   #27
ArcticEOS
Junior Member
Default
Our reciently aquired 2010 EOS with DSG has this chuga chuga chuga when starting off from a standing start. The transmission functions perfectly as long as I don't come to a complete stop. The dealer we purchased it from says, "they all do that." but I find it very uncomfortable to drive in traffic. Should I be finding an independent VW mechanic?
ArcticEOS is offline   Reply With Quote
Old 08-14-2018, 07:59 PM   #28
mickjane2
Senior Member
mickjane2's Avatar
Default
Quote:
Your DSG gear box should be smooth as silk, if there is a judder it could be the clutches and if you can feel the gear changes in normal driving mode itís probably the mechatronic unit playing up IMHO.
Mick
__________________
Sponsored Links
Advertisement
Old 08-15-2018, 01:35 PM   #29
ArcticEOS
Junior Member
Default
Thanks Mick,
I think I knew the answer before I asked. I made an appointment with a local transmission shop to have a look at it.
I have a feeling this is going to be selling a kidney on flea bay expensive.
Jeff
Old 08-16-2018, 07:24 PM   #30
ArcticEOS
Junior Member
Default
Good news, the transmission shop put it on their machine and checked the function of the transmission and it is functioning normally. However I've got a bad coil pack, the engine is shuddering causing confusion within the transmission. It is only doing this just off idle. Booked it in for a tune up and having the bad coil replaced. yipee
Old 08-17-2018, 06:59 AM   #31
mickjane2
Senior Member
mickjane2's Avatar
Default
Nice one glad your problem is being sorted much more cheaper than a new gearbox.
Mick
__________________
Old 08-20-2018, 05:56 PM   #32
ArcticEOS
Junior Member
Default
It gets even better. It was 2 injectors causing the misfire not the coil pack and they are covered by an extended warranty from VW. Total Cost, Zero
Old 08-20-2018, 09:13 PM   #33
mickjane2
Senior Member
mickjane2's Avatar
Default
__________________
Old 09-18-2018, 02:07 PM   #34
ArcticEOS
Junior Member
Default
Update, The chugging upon take off came back the next day. I couldn't find an independent transmission shop that would touch the DSG so I ended up back at the dealer. They told me this morning (they had the car 3 weeks) the mechatronic unit was replaced and it "runs like a dream" now. Time will tell. repair was just shy of $2500
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
