Performance Clutch Kits and Flywheels from CLUTCH MASTERS for your EOS - VW Eos Forum : Volkswagen Eos Forums
Go Back   VW Eos Forum : Volkswagen Eos Forums > Vendors > NOPI.com
Reply
Thread Tools Display Modes
Old 04-27-2012, 02:43 PM   #1
nopiman
NOPIMAN
nopiman's Avatar
Default Performance Clutch Kits and Flywheels from CLUTCH MASTERS for your EOS
All stages come as a complete kit including disc, pressure plate,
throwout bearing, pilot bearing (when applicable), and alignment tool.
Assembled in the USA
FX100: Street Performance Clutch Kit
The FX100 System uses the Power Plus I Pressure Plate with a custom heavy-duty Steel Back Organic friction disc. This clutch is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust system, an intake system, up to 50hp NO2 upgrade, or other non-forced induction external bolt-ons. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation.
FX100 Clutch Kit
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Dampened hub steel-backed organic lined Dampened disc - Hydraulic slave cylinder incl
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - steel-backed organic lined Rigid disc - Hydraulic slave cylinder incl
FX100 Clutch/Flywheel Kit
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc - Steel flywheel incl - Hydraulic slave cylinder
FX200: Street Longevity Performance Clutch Kit
The FX200 System uses the Power Plus I Pressure Plate and a Steel Backed Kevlar disc. This clutch is designed for the street enthusiast or weekend racer. The FX200 offers similar torque holding capacity to the FX100, however, its life expectancy is increased 2-3 times with the Kevlar disc. Our Kevlar friction material is non-abrasive and doesn't score the mating surfaces. It features only slightly increased pedal pressure, significantly longer life than stock, and normal clutch feel during engagement and disengagement for the smoothest operation of any stage we offer.
FX200 Clutch Kit
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc - Hydraulic slave cylinder incl
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate -full-face Kevlar lined Rigid disc - Hydraulic slave cylinder incl
FX200 Clutch/Flywheel Kit
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc - Steel flywheel incl - Hydraulic slave cylinder
FX300: Street/Race Performance Clutch Kit
The FX300 System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement.
FX300 Clutch Kit
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Dampened hub segmented Kevlar Dampened disc - Hydraulic slave cylinder incl
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - segmented Kevlar Rigid disc - Hydraulic slave cylinder incl
FX300 Clutch/Flywheel Kit
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Dampened hub segmented Kevlar disc - Steel flywheel incl - Hydraulic slave cylinder
FX400: Race Performance Clutch Kit
The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4 or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more streetable than solid or rigid designs. This disc is designed for long life, outstanding holding capacity, and rapid heat dissipation.
Warning: Due to the solid (no Marcel) friction rivet design, the FX400 disc engages very quickly and may chatter slightly in first and reverse. To help alleviate this problem, we only use premium ceramic friction material.
FX400 Clutch Kit
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Four-puck Rigid ceramic disc - Hydraulic slave cylinder incl
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Six-puck Rigid ceramic disc - Hydraulic slave cylinder incl
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Lined Rigid ceramic disc - Hydraulic slave cylinder incl
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Four-puck ceramic Dampened Dampened disc - Hydraulic slave cylinder incl
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Six-puck ceramic Dampened disc - Hydraulic slave cylinder incl
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Lined ceramic Dampened disc - Hydraulic slave cylinder incl
FX400 Clutch/Flywheel Kit
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Four-puck ceramic Dampened disc - Steel flywheel incl - Hydraulic slave cylinder
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Six-puck Rigid ceramic disc - Steel flywheel incl - Hydraulic slave cylinder
10~11 - 2.0T TSI 6-Speed 4Cyl - HD Plate - Lined ceramic Dampened disc - Steel flywheel incl - Hydraulic slave cylinder
Lightweight Flywheels
Reduced mass equals increased acceleration. Reduces turbo “lag” in turbo-charged engines. Increased supercharger efficiency due to less drag on the crank. Improved mid-range torque in normally aspirated engines. Two-piece unit featuring a high carbon steel replaceable friction surface. SFI Certified. Rev Quick - Typically 50% Lighter and Stronger than OEM
10~11 - 2.0T TSI 6-Speed 4Cyl - STEEL - lbs
GO TO NOPI/CLUTCH MASTERS Catalog for model specific web prices and details
Contact the salesmen below or PM me for our best deal on CLUTCH MASTERS Clutch & Flywheel kits
__________________
NOPIMAN
NOPI.com
Since 1966 • 800-277-6674 • Bobby ext. 207 or Rusty ext. 261 • M-F 9-6 EST
Upcoming NOPI Events
NOPI EVENTS
nopiman is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
