1 - 12 of 12 Posts
Time Lord
Just recently became the proud owner of an 08 Eos. Currently own an 08 GTI with a few mods (K04 and supporting, Coilovers on 18" Serrons, aftermarket radio, shiftknob, shift boot etc).
Been interested in the Eos off and on for a while but recently starting looking for first gen models at a reasonable price of entry.
Now, I'm also an fan of the Youtube, and especially the guys buying salvage cars that need a little love. So I messed around and bid on a car... low mind you, just to see what would happen.... and I won. Car needs drivers fender and headlight and front bumper.
Part of me is asking WTH have I gotten myself into and the other thinks I got a helluva deal. Parts have already been sourced and should set me back less than $200.
My GTI has the FSI engine so cam follower check and timing belt change are on the list of to do's.
Will add pics later but just picture Silver with white interior.. ;)
Time Lord
Discussion Starter #2
Car arrived a couple days ago with a few issues right from the start. Wouldn't start (battery dead) so couldn't get it out of park to get off the roll back. Miscellaneous parts were in the car ie bumper, taillights, side view mirror but the seats (front) were completely destroyed from weather. Driver window was down and passenger side was partially down.
Did get the car in neutral by pressing the switch at the base of the gear shift (thanks youtube). The car as a first impression was a POS... and the wife's expression was the icing. Car wouldn't start with a jump. I woke up that night with the car on my brain LOL.
The next day I decided to mess with the car to try and have something positive to move forward with. Moved my GTI battery to the EOS, put in a gallon of good gas and...... she fired up!!! Engine sounds (and looks) like a well taken care of car... transmission shifts nicely from the short drive into the driveway. So if all else fails I can get my money back... LOL.
With the good battery in the car I was able to completely raise the passenger side window. I attempted to open the sunroof. It opened fully with no issue. Attempted to start to open the roof but I didn't have the cargo shelf in the correct place. The dead battery was still (8/17) under a 2 year replacement warranty so was able to get a free battery replacement.
This forum helped with the driver side window issue. Apparently the window needed a reset with the door lock. Locked the door holding the key to the right and the window rose and stop. Repeated and the window fully closed and now works properly!! Car now starts at the first turn of the key. Tried the a/c and even it blows cold. Replacement fender, headlight and headlight bracket have been installed. Only thing remaining is to install the front bumper (waiting on the fender guide I purchased). Was feeling positive enough to even give the car a wash LOL.. and the paint is in good condition also.
LSS, I'm about $900-1000 into this car and I'm pleased with what I've purchased. I can source mk5 era leather seats for about $75 for the pair. A good detailing of the interior will happen at that point or at least when I decide to remove the damaged front seats.
There's still some damage at the drivers rear wheel arch but nothing a pull and a little bondo fill can't remedy.
Plans are to keep this car stock except for possibly a set of 18" OE wheels and lowering springs or coilovers.
Wife looks at me like I'm a little less than crazy now LOL
Time Lord
Pictures as it sits today. I'll include before and after of the interior (seats) once I've replaced them. The ones in there now are just that bad..
Sent from my Nexus 6 using Tapatalk
Nice to see someone trying to keep as many of these cars on the road as possible! It always makes me sad to see an Eos get scrapped - even though it makes it easier for the rest of us to find parts ;) Good luck with the rest of your restoration.
Life is good... so far
If you have a good motor, trans, and roof, that is most of the battle. I would suggest carefully checking the trunk for corrosion/rust.
Time Lord
Discussion Starter #7
Engine and trans are good. The weather has prevented me from opening the roof and I want to clean and condition the seals when I do.
I pick up the front bumper/fender guide tomorrow. Weather permitting I plan to pick up a pair of interlagos front seats from a 2 door GTI also. Need a few screws to mount the driver mirror and door card handle and we'll be good to go.
Time Lord
Discussion Starter #8
Sourced a couple of 2 door GTI interlagos seats. Going to have to tear into the passenger seat to get it out. Looks like the motor is dead.
Tried dropping the top and it all went well until the roof didn't unlatch from the windshield. I'm still having a few issues with the drivers window and wondering could that be preventing the top going down? (Window goes up and down work the switch but one touch up/down isn't working and the window drop when opening the door seems to drop a hair too much and doesn't go back up once the door is closed).
I'll look at hooking up the car to obdeleven to check what faults there might be, tomorrow if time permits.
I'll also be picking up the bumper to fender guide tomorrow from the dealer so the bumper can go on.
**Any suggesting/insight to my few issues are appreciated**
Time Lord
Discussion Starter #9
Making steady progress with the car. Fender guide came in and was installed. Front bumper was put on with little issue. Seats were finally installed. They need a little cleaning but don't look out of place. Have to swap over some wire connectors from the eos seats and that should get rid of the airbag light. Driver's door handle was installed. Cleaned up the driver's door card and will likely install it tomorrow, time permitting.
Tried to drop the top today (still haven't checked for faults yet) and the top wouldn't retract at all. Now that I think about it, I'm hoping the shelf in the trunk just isn't stowed away properly (fingers crossed). The car with the airbag light removed should be ready at that point for the rebuilt title inspection. I'll probably hold off on that until I know whether the top is functioning properly or not. I don't want to get in too deep $$$ if there's no hope of top down motoring LOL. Still need to do an oil change/filter, air filter and plugs and fuel filter. That's all based on the top retracting..
The scuffs along the door were mostly removed with laquer thinner leaving the small damage to the rear wheel well. The damage is just enough to warrant a repair but also just enough that I feel I can tackle the repair myself... so we'll see how that goes.
Wish me luck!
Good luck! I guess if you don't have the highline display in the dashboard you won't be able to see why the roof doesn't operate - but there can be issues with the microswitch that detects that the luggage panel is in the right place. Fingers crossed it's something simple. :)
Time Lord
Discussion Starter #11
Car is still coming together. I should have it registered later in the week. Car passed safety inspection today. Front fender and rear panel will be painted in the next couple weeks. Still looking for a replacement grille that doesn't cost $200+... even for used! Wish there was still a badgeless grille on the market for these cars.
Short term plans are to lower it a little and possibly pick up a set of 18" VW stocks off of a GTI/GLI/CC. Trying to keep it at a height that the wife will feel comfortable jumping in it and driving it without too much worry. But we'll see LOL.
Will update with pics soon..
Time Lord
Discussion Starter #12
Car still runs like a champ. Will need a thermostat replacement at some point. Found a grille for ~$100. Installed a MK5 GLI steering wheel so I can have dsg paddles, cost me $40. Replaced the premium 7 with an RCD510.. $25. The car still needs paint but I'm wavering between keeping it and selling it for what I have in it. I'm pretty satisfied with how my GTI sits so it's hard to have the EOS and not modify it lol... modify it and I'll have to keep it long enough to get my money's worth out of it since I won't by selling it with modification.
We'll see...
Sent from my Pixel XL using Tapatalk
1 - 12 of 12 Posts
