Greetings everyone, I just bought this car 2 weeks ago with a perfectly working top and of course, 2nd week it fails.
Upon pressing the button down, all 4 windows roll down, the sunroof opens up fully, and then I hear a whining noise and everything stops. Rear window frame doesn't budge and I do not hear the latches unlock at all.
I checked the pump in the back, removed the electric motor and hooked it up direct to the car battery and it's running like a champ. I had thought that the motor may be shot but it's good. The hydraulic pump reservoir has oil and it's fine. The pump area was a little oily, greasy, perhaps there's a small leak from the lines but I wouldn't think it would be the cause.
I hooked up to scanner and Hall sensor shows 1 1 1 1 0 1 1 0 0 1 1 and doesn't move at all from that status. I understand bits 3 and 4 need to go from 1 to 0 upon the rear window frame unlocking but they do not.
What's my next logical step here? I am a skilled DIY, very patient, methodical. If I can be pointed to the right direction I would appreciate it. Should I follow the youtube video that shows how to manually pop open the rear window frame and then hope to see a fault there somewhere or should I undo the pillar cloth on the C pillar and take a peak? something else maybe?
