Hello everybody,
after sorting all sorts of crazy thing on my car, I came to the next thing that I can't quite figure out.
So the car came with the old style ac control module, the one with the temp displays for driver and passenger that indicates the temperature.
The problem was that the dials were jumpy, if I turn up the temperature on the display was randomly going up or down on the display, and I felt like every temperature was the same (no regulation what so ever) unless I got it set to hi and then it would be warm.
So I bought a new style ac control unit, the one that has the numbers on the side of the dials, and I noticed that nothing has changed whatever I set the temp at will blow cold, only thing changing is the fan speed, and the only way to get warm air is to set it on hi.
The car is equipped with climatronic, so the swap should be plug and play for what I've read here in the forum.
Any Ideas on what can I check?
