Working on a customers' car, roof would not operate, trunk would not open. Figured out how to manually manipulate the trunk and roof, gave up on repairing the roof after we realized that someone else had been in there, and removed the Front Left bracket for the rear glass section to get it to close 'properly'... There was also other fiddling with the left side mechanism, unfortunately this customer does not have the money to devote to making it right.
So, the problems that remain and stop this from being a usable car are;
1) Can't open the trunk with the remote, or the mechanism on the trunk lid, Only by the emergency release cable. I hear no servo function, we replaced the trunk latch as it would no longer open by emergency release in center of back seat.
2) Sunroof will not fully seal, is stuck in vent mode. If I operate it from fully open, it will not close Unless I operate it about a second at a time, and wait about 20 inbetween each use. Nothing seems to affect the state of the sunroof. The only roof-related code is 02805, which is there because that bracket for the rear glass is removed. It coincidentally holds a sensor in place, which is of course now dangling...
3) Upon doing a scan with VCDS, Central Electrics (Body Control Moldule) Shows there is a fault once I do a body-wide scan, but once I go into it, there is no code; therefore, perhaps the BCM has fried with all these other problems? With it being Unlikely the roof will revive, I hate to buy one without some guarantee that it would be worth the effort...
4) Driver's door glass will not drop with the door opening, no code there.
I apologize for the laundry list, not as familiar with these cars as I might be to be helpful... Let me know how I can help you, to help me...
Thanks,
Dave
Thanks,
Dave
