Been a while since I have been here. Originally I had a "Check Engine light fault come on every time the outside temp went below 20 degrees and stayed that temp. Once it rose above the light would go off on its own. Never did find out what was wrong with it, replaced everything the VW dealer could including an new EMC. I think thats what its called . The brains to the car. I have since moved to Arizona and will not have to worry about it coming on anymore.
My new concern is that after I have driven the car 3 to 5 miles and turn it off it smells warm, like rubber, coolant getting hot, So I popped open the hood while it was running and I noticed the 2 fans for the radiator were not running at all while the car was on. As soon as I turned it off, about 5 mins later they kicked on for a few mins and shut off. Now it was a mild day here for AZ, about 70 degrees. Is this typical for this car or is there an issue with the cooling system? I don't drive the car much. Its a Sunday type car. Any input from the experienced VW owners would be appreciated.
Don
Don
