1 - 2 of 2 Posts
I have receieve a error on my MFD display saying Error ACC, All the key changing information has dissapered and when the car is in motion the mileage dissapers and is replaced with a icon you can see in a photo.
I believe the icon is a cruise control error, I have look up and ACC means Adaptive Cruise Contro;, my car is 1 2013 model and doesn't have ACC.
This photo display when the car is moving, Also the gears that use to appear at the top where the time is have dissapered as well
22545
This photo is the error displayed in the MFD display.
22546
Has anyone had this problem before and what can i do to fix it.
Do you have the EOS driver manual which should be in the tray at the top of the glove box? That shows all the warning icons and the yellow one in your photo is a bulb failure warning, because it looks like a light bulb!
To fix both errors you need more detailed information from a diagnostics scan. But have a look at all your lamps first and see if any are out.
1 - 2 of 2 Posts
