1 - 2 of 2 Posts
Hi Guys,
I am facing an issue with the AC unit of my 2008 2.0 TDI EOS and wonder if anyone can advise any solution?
When I turn on the climate (A/C on) it seems it will not engage (no click and no rpm up) but checking the compressor the inside part of this also spins.
I have checked all the fuses and changed the relay (no. 53).
Obviously it does not produce any cold air.
thanks for any asnwers :)
Check the electrical connections to the compressor. I had the same issue on my wife's Golf Mk4 and it turned out to be damaged wire to the compressor clutch.
1 - 2 of 2 Posts
