Initially I figured the K&N panel filter would be a simple install/video, but after taking everything apart, it became apparent that additional work was needed.
After removing the OEM filter, I found a diverter valve in the rear of the airbox, basically making the internal volume of the air box much smaller and when activated, this diverter valve would draw in hot air from the engine bay. Additional research netted me with little info about this device and its purpose. Some speculate its for emissions and others that the diverter valve is in case the primary air inlet gets clogged with snow. FWIW, the euro R32 (which has the same airbox) does not have this diverter valve.
The diverter valve is not electric, nor is it controlled via vacuum, so my best guess here is that it has some sort of thermal valve that opens/closes based on temps. The valve in my box was open, even though it was cold out (the vehicle has not been driven for several days). The valve is held in with three screws, so easy enough to remove. I applied heat to the valve module, thinking that would make the diverter move, it did nothing. My end conclusion is that the valve in my airbox is non-functional and stuck in the open position.
I plugged the diverter valve hole with high temp aluminum dryer duct tape (both sides, two layers).
Also, the air inlet upon close inspection actually splits and the majority of incoming air is directed into the engine bay and there was a larger angled piece of plastic blocking airflow into the airbox. I used a rotary tool and removed the blockage and defaulted back to the high temp dryer duct tape to seal up the air inlet so all of the incoming air is directed into the airbox.
The air intake system is now a close eco system and the air flow has been increased and the volume of the airbox has also been increased. The K&N panel filter flow rate is roughly 514 cfm, higher than the AFE 5r.
