Guess I'll try not to hit anything on my way over to the service department next week
....and in some parts of the country this same "virus" mirror images the controls and causes susceptible individuals to drive on the wrong side of the roadDarren,
I think this is a very serious virus:![]()
It seems to have converted l/100km to mpg, km/hr to mph and other such conversions on all of your instruments.![]()
You should immediately run a virus checker, or install the latest version of Windows immediately (Damn Bill Gates)![]()
Nice one DarrenDropped it off today and the service advisor said that behind the steering wheel there is some sort of connector that is like a lazy susan. It allows everything to stay connected and rotate with the steering wheel. He said that is what the problem is most likely to be. He didn't mention if this is something they have in stock. I hope so, but in the event it is not, at least I am holding hostage their 2009 Passat 2.0T which was brand new with 23 miles on it. Not exactly their service loaner but it was arranged quite kindly by the salesgirl I bought from.
Shouldn't take too long for the dealer to replace the clock spring, once they have the part in hand. I replaced one myself on another airbag-equipped car of mine. For once, I made darned sure the battery was disconnected before starting the job! Airbag in the face = not good.Apparently called the "Clock Spring". Of course, had to order it. Maybe today...maybe Monday. So far I've put 100 miles on their Passat. Interesting how the same engine feels less impressive in that car. Not bad, just not "all there". I'll have to compare gross weights of the two.
Hey guys, new member to the forum. I have a 2008 black EOS.
I was about to have my car serviced for the 20,000 mile marker when the 'Airbag fault' message popped up. After looking on this forum/ this page i found that it was the clock spring in the steering wheel shaft.
Turns out that was exactly it, not to mention it was covered under warranty. Thanks for the info.
Hi guys, i have the same problem regarding the "airbag fault".Hey guys, new member to the forum. I have a 2008 black EOS.
