According to the manual there is an aux in for audio and video on the nav unit
any idea where?
would have prefered ipod connection in armrest but car came with cd changer, is it under that?
plus does the ipod play video on the display?
cheers
That would be brilliant! but i doubt it, the thing doesnt play DVD's so im assuming the firmware blocks any video playback (Any possible way around this perhaps??, seems a waste for it to be able to read DVD's but not play them!), also is the ipod preperation just the USB slot in the armrest? do you just use the ipod cable to plug into that?
manual states there is an aux in and in the settings on the nav unit you can select aux in audio or both audio and vid so reckon there is such a port on the back or somewhere in the car, if it was easy to pop out i may give it a look as am engineeer
if you set aux in to audio and vid then screen goes blank waiting for a signal so input must be there!
plus manual states you can connect a dvd player to it so an ipod vid would be ideal
further investigation required i think :D
Pacemaker ... I have just noticed that there is a specific EOS section in the Forum at the VWvortex website, and it appears to have a ton of technical information, including a lot of stuff on ipod, etc. There is also a search function, so you can restrict the threads in which you are interested. Hope this is of some help. Good luck!
