If it's the 9W7 version it will do both (but only if you have the white high line MFD). ****I'm not sure if we're after the same thing but I found a post while trawling through the forums where someone has fitted this module which works nicely with the iPhone. Not entirely sure if it's just for calls or for streaming as well.
white high line MFD?If it's the 9W7 version it will do both (but only if you have the white high line MFD). ****
Sorry Multi Functional Display in gauge cluster. ****white high line MFD?
Oh that you will. ****Yup, got one of those. I've got a big one. fnarr. I presume that is the high line and the half screen is the low line.
Learning so much today.
