As paul-c says, I think your problem is the pull down motor may be making a noise but isn't moving the keep roller up and down? When the roller is down, it's too far down for the upper lid lock claw to engage with it. Do as he says and watch for the roller moving up and down. If it doesn't move (up) but you are getting noise from it for up and down, it's faulty inside. If there's no noise at all, investigate power and the roof controller.I close the boot and it just stays ajar and doesn’t lock.
There is a small metal clip that is lodged into the boot lid at the lower left side. This clip can easily come out over time. If this clip Is missing the boot will not show it is locked.Hello. My book lock suddenly stopped working and I can no longer lock the boot. Any ideas why this may have happened and how to fix? as can’t visit a garage at the moment. TIA
HiHello. My book lock suddenly stopped working and I can no longer lock the boot. Any ideas why this may have happened and how to fix? as can’t visit a garage at the moment. TIA
Photo please because I always thought the trigger for boot locking came from a switch in the upper lid lock which connects to the central convenience control unit?There is a small metal clip that is lodged into the boot lid at the lower left side.
The 'issue' is a wet trunk? The three pins are power and control. If those pins are corroded investigate water leaks into the trunk, search here for 'gremlins', look at connectors on the roof control and parking control modules.I've found the issue
but if you search you'll find a mod. from me which removes the box and foam completely.
