1 - 2 of 2 Posts
Hi gys.I've been told that it's possible to install 20 inch rims on my eos.Is this right?Curently I'm with 18" and I fall in love with two 20" models on Touareg and Audi Q7.What tires should I use to fit these rims?Maybe 25mm or 30mm?
· Life is good... so far
Yes it is possible. VW was showing off a car concept that had 20 inch wheels. I think they called it the Highway 1. If you follow VW size progression of 17/45 and 18/40 that would suggest that 20 inch would use 30profile tires. Also VW suggests the use of XL rated tires. Can't help on wheel offset info but I'm guessing that might be 39-45 mm range. Have to check with wherever you buy the wheels.
1 - 2 of 2 Posts
