My ignition lock has failed. I cannot remove my key from the ignition switch of my 2016 Eos (non KESSI) I tried several solutions stumbled upon on the internet, like juggling the keys, or allowing the key to spring back to the original position. The ignition will turn from off, to acc and start and run the car, and back off again. But the key will not release. I took it to the dealer, they said it was the housing, not the actual cylinder, and replaced it to the tune of $700 and a 6 hour wait. That evening when returning to my house, same problem, I can't get the key out. The car is in my garage with the key stuck in the ignition. VERY FRUSTRATED. Wondering if I can get a KESSI system installed, it was an option on earlier models, but I'm not sure if they offered it on the 2016's. But I do not have the touch door handles (or probably the wiring needed either).
Open to any suggestions, Thanks.
