1 - 1 of 1 Posts
Did you know that car diagnostics could forecast the weather - tell you if a cyclone, hurricane or weather bomb is on the way?
You can fairly accurately read out barometric pressure from the MAP sensor so I assume it will tell you if its good weather ahead (MAP pressure rising) or bad weather (MAP pressure falling). Beats tapping the glass on Grandmas aneroid barometer. :)
1 - 1 of 1 Posts
