· 60 something of Ruislip
I bought my new Eos in October 2007. In February 2008 I took it into my local VW dealer Citygate Volkswagen, South Ruilsip, Middlesex UK They took it on a road test and said that it needed a new steering rack and duly installed one under the warranty.
On 13th November 2008 about a mile from my home I lost control of the car. I later realised that the steering had suffered a catastrophic failure. I felt relieved that this had occurred on a minor road when I was going slowly and no one had been hurt. The previous day I had been on a long motorway journey with my wife. Had I lost control then at 70 mph I may not have been here to write this note.
:eek:
I called my breakdown company. The technician removed the cover under the steering column and exposed the universal joint at the bottom of the column.
The lower part of the u/j consists of a clamp which grips onto a male shaft on the steering rack through which the turning motion is transferred. The shaft has longitudinal grooves to ensure it grips firmly when the bolt on the clamp is tightened. I gather the end of the shaft incorporates a protrusion which goes behind the bolt so that it would be impossible for the shaft to work loose when the bolt is firmly in place.
The technician said that the shaft had come completely away from the universal joint even though the bolt was tight. He was most emphatic on this latter point. He said he had seen nothing like this before. At my request he recorded his observations on paper. I also took photograph of the u/j before he reconnected it to the shaft. It showed the bolt was tight.
I subsequently took the car Citygate Volkswagen, and gave them copies of the note and photograph and explained what had happened. They took it in for repair. I later raised the possibility with one of their staff that two components may not have been fitted securely when the steering rack was changed. I was told that this was unlikely as he thought that there was no need to disconnect them when a new rack was fitted. I later learnt that this was not necessarily the case.
When they called to say the car was ready I was told that the bolt had been replaced. I asked to be given the old bolt. Later, I was told the bolt had not been replaced; it had been treated with Locktite and retightened.
I fed these events back to VW’s UK headquarters’ Customer Care Department. They asked Citygate Volkswagen to investigate and report back. Citygate Volkswagen in their report said:
“ The investigation concluded that all of our safety & quality procedures were fulfilled in the original & consequent repairs. It is not possible for us to know what may have happened in the intervening months between the original repair in February 2008 and the failure in November 2008, a period of 9 months.”
At no point had Citygate Volkswagen asked me what had happened to the car in those intervening months. Nothing in fact had been done to the car that would have had any impact on the steering.
In February this year I asked Citygate Volkswagen if, just to be on the safe side, they had re-called any similar work to check that it had been carried out correctly. They said they had not done so.
I believe this was the wrong approach as the most plausible cause of the failure was that when the new steering rack was fitted the shaft was not pushed in far enough into the clamp before the bolt was tightened. Consequently the protrusion did not sit behind the bolt securing the shaft properly into place. Gradually with use over the months the shaft worked its way loose.
I would be interested in the comments of any other Eos owners.
To be honest, I'm not happy with the Citygate local to me.
They don't look after your properly like say someone from Lexus or, dare I say, even Audi. They just want to sell cars, and get you on your way. The first time I called up about my leak, they have the audacity to say 'thats the first we've heard of a leaking Eos'. LoL give me a break.
No reason why you couldn't have just rejeted the car and got all your money back. As much as I'm proud of my Eos, I have always felt that VW rushed their CC. It was one of last ones to hit the market, and I think they cut alot of corners in trying to make it the best in its class (which performance-wise it most definitely is).
Why don't you still try and reject it? In your case, I would definitely give it a go. If they refused, take them to court, get a good lawyer behind you & make VW give you the refund, and pay for all legal fees incurred. I know it sounds daunting, but if bought yours new in 10/07, you would have peak prices - so its definitely worth it.
Kuz, Thanks for your comments.
The problem arose not because of faulty manufacture but with a faulty repair. I do not therfore see how I could claim a refund on the purchase.
What I wanted was recognition by Citygate that they had (almost certainly) made a mistake and that they were taking steps to check other steering work that they had carried out to ensure other lives were not being put at risk.
They wont do that as it could cost the a potential fortune and therefore be seen as not doing their work properly which is obviously what happened in this case. They would then also be admitting liability for what happened to you and then you could sue them for it. The possibility of them doing a recall is nil i think.
I think that some of the VW garages we have used certainly the one i've used and the ones both you and Kuz have used don't give two monkeys about customer service aslong as they get a sale and dont see you again. Thats the impression i've got of them.
Im still awaiting a reply from VW UK about my car because of the lame service I have recieved from VW.
At the end of the day we pay good money to have a good standard of car and it doesnt look like we're even getting that standard. You would expect these sort of problems to be with the cheaper manufactures that one of the more expensive ones.
I know that quite alot of people on here are happy with their EOS and Im glad that they are but there are still quite alot of us that aren't happy either. I just hope that non of the problems we've had happen to them.
I hope that you get it sorted soon and thank god your still alive!
Steph xx
Yes, I am glad I survived too.
Its mind boggling to think of all the fast motorway journeys I had been on since the new steering column was fitted and all the time the shaft was working loose from the u/j.
I cannot sue Citygate, even if they admitted fault, because I suffered no damage (miraculously).
I am worried about the other steering racks that the same mechanic may have fitted. Who is driving around with one of those right now?
· Former Focus CC3 owner!
Blood VW dealerships are poo!
Steph et al where do I complain about my local dealer? Is there an address or e-mail address or telephone number or something? I'm sick of the way I've been treated. I didn't spend £20k on a VW to be treated like I'd just paid 50p and am worthless to them just because my work is covered on the warranty. :mad:
The number for VW UK Customer Support / Care is 0800 0833 914. They were very helpful a few years ago with a Golf GTI I was having problems with (even though it was an import!). Hope this is helpful. Wouldn't bother writing as in my experience emails never get read / replied to and post never gets there / replied to!
Good luck Doolallygirl
