Now that my sat nav is now fitted and working I am on to my next project, fitting a 6 CD changer. (The MFD2 sat nav won't play CDs)
I know it is fitted as standard into the arm rest. Has anyone ever converted the standard arm rest insert into a CD insert. Also is the cable that comes with the CD changer long enough to reach the MFD2 unit, or will I need an extension. Also does the unit plug into the same connector main car connector does or does it plug into the auxiliary socket. That would rule out using my A/V interface.
Lots of questions I know.
Thanks if you can help
