I just finished a major upgrade (radio, instrument cluster, climatronic) to get rid of the old blue/red color scheme.
One of the things I replaced is the climatronic unit. I had the MY07 one, with the blue gauges.
I found one on eBay that was suitable (from a passat cc).
To do the upgrade you have to follow a couple of steps :
- In the largest of the 3 connectors , cut the pin20 and pin16 wires. Connect the wire that went to pin16 directly to pin20 on the connector. The other 2 wires can be taped off, they don't have to be reconnected. This is necessary because otherwise the climatronic unit won't remember its last setting and will be in the off-position anytime you start your car.
- The first time you use it, hold the AC button together with the upper-vent blower button for a couple of seconds. The LED's on the buttons will blink for a bit . When they stop blinking , hold the AC button together with the rear window heater button for a bit , the compressor will now calibrate.
- You also need a new fascia because the new climatronic has a different shape. Partnumber is 1Q0 858 069 J 041 in piano black. They also exist in silver but I liked PB more
It took the VW dealership 3 days to get it , it costs 45 euro.
