1 - 2 of 2 Posts
2009 VW ESO 2.0 TSI
I have 2009 eso, yesterday I put the top down and everything worked fine. Returned home and went to close the top, the trunk lid open fine, the top stared to close came up about 12“ and stopped. ( the pump stops ) I checked the oil in it’s fine. I’ve looked all over the inside of the trunk compartment and everything looks fine.
I wait awhile top will settle back down, I’ve tried it several time and the same thing, the pump starts, top come up about 12” and the pump stops
Wheel Tire Automotive tire Car Motor vehicle
Automotive tire Hood Automotive lighting Motor vehicle Vehicle
When the roof operation stops part way due to a fault, the sensors know where the parts are. If roof parts then settle into another position under gravity or are moved manually, the roof controller can't understand the position the parts are in because it expects to continue where it last stopped. The roof operation expects to always run from start to finish unless there's a fault. It's a problem fault that needs diagnostics to further investigate what's going on.
1 - 2 of 2 Posts
