So, the Corvette style tail light mod is common on GTI's and Jettas. Normally you can turn off the inner lights via VCDS but the settings that work on the other cars does not work on the EOS, or at least the year of my car and/or the fact I am in the US..
Had to remove the light and experiment by removing wires. Found out that if I remove the black wire, the center light section goes off. I removed it from the plug and taped it to the back of the ckt board, and can reverse this very easily if needed. The small LED running lights on the side also turn off when removing the black wire, even though they have separate wires going directly to them.
The outer ring is also the blinker and works. Brake light is the center section and lights when you step on the brake.
With the center section off, I also noticed two LEDs that are out, the ckt board had some corrosion, so I cleaned that up, not much I can do about the two led's that are out, except purchase another tail light.
Going to do a video on this Friday when I do the other tail light, hopefully I don't find any more LED's that are out.
