Hi everyone,
My eos drives fine no problem at all only problem I have is dash lights then I indicate.
Then I indicate left everything is fine but then I indicate right hazard lights on and 3 others ( fuel light, boot open and coolant level) . Coolant level is OK so and fuel and the boot is closed.
Just wandering if anyone had same issue.
Any help would be much appreciated
Have you been messing about changing batteries, let it go flat or been jump starting? Something is very screwed up. I would use decent diagnostics first to see what it finds, then operate the controls and see if it finds something or nothing, then go into some of the diagnostics test blocks where from a laptop you can check first if CANbus commands are doing the right thing. If they are, then start looking for crossed wires if they aren't, then look at possible module faults. Last resort you could try leaving the battery disconnected for a couple of days then reconnect without arcs & sparks.
