This is the first experience of a leak on our 2007.
Wifey drives it most of the time. Today, sitting as a passenger with her driving in the rain, I could see and feel water dripping through the door glass, down into the door skin, front carpet and my knees. I looked over to the driver side and that was similar, but not as bad.
I can see the problem is poor design. The top section of the door glass seal in the roof section is formed as a U Channel. But the front section in the A frame relies mostly on surface contact with the top edge of the door glass, because the glass has to pull away when the door is opened. But I think they could have tried to get a seal profile that would come up against the inside surface of the glass.
What to do about it? Well Krytox isn't going to fix it. I fed some thin paper in whilst closing the door and there was very little friction between the glass top edge and seal along the front edge.
The door glasses are aligned according to spec. First I'll try raising the glass a little to get better contact with the seal, even if that means setting the glasses just on or outside the lower marks.
As a last resort I might try fastening some 20mm wide adhesive backed black foam rubber to the front section of the seal. As the glass comes up, the top edge should pinch into it if it is sufficiently soft.
