Greetings
Need some help. I have had a 2008 Eos since late 2009. Have had some issues here and there but this latest one is stumping me. Over the last couple of months whenever I put my top down everything at first appears fine. When I stop and get out the drivers door will not close. It just bounces off the latch when you try to close it. It only does it when the top is down. Does anyone have any ideas?
Thanks very much
Member
With the roof down when a passenger exits does their door shut normally?
Had similar. Seems micro switch in door is not working as should and the window has raised fully as if the door is shut. Seems to work on mine with just pressing the unlock on fob and it will drop the little bit to and allow the door to shut.
