Hi.My Car has done 56K,.. 25 of this mine, and very carefully driven. There is a coolant leak, confirmed by a pressure test. Garage says two possible causes; cracked engine head, or the egr cooler.
Interestingly, they were to force the engine to heat up ( by running at 4500 revs) in order to do a dye test and use a scope camera. However, they stopped as the engine was 'clattering' - a sign of wear only likely to get worse.
My dilemma and question is - do i replace the egr cooler as the cheaper suspect, or go for the engine rebuild / replacement as the likely cause (.. and the elephant in the room ultimately)
I notice on other threads coolant leaks are hard to locate... Also, Has anyone replaced an Engine/ rebuilt top end before ? ( its a TDI dsg 140bhp model ) Thanks
