I'm new to the EOS and have been going over my new buy 2016 21,000 miles 1 owner car for anything easy to see and fix, I noticed the hydraulic resevoir wasn't up to the full mark is it best to check with the top up or down and what fluid do you fill it with ? Thanks Mike
You may have a problem if the level has dropped, as it is a sealed system so there must be a leak.
The oil you will have to get direct from VW, but I would want to know where it has gone before putting more in...
The reservoir level mark is about half way up the reservoir. MY07 level has never changed, therefore no leaks! Best to assume fluid in there is genuine V.W and top up with correct fluid from the dealer. What goes in comes out, it doesn't matter what position the roof is in. Check it closed.
