Hi, i have recently bought a 1.6 2007 vw eos pre facelift, with a faulty roof, leaking seals and occasional engine light (I baught it for 750£ as my first car 2 days after passing my driving test, and since these usually go for around 2000£ i didnt expect it to be perfect haha) i love it, looks cool for a first car and cheaper to insure that a 1.0L deawo ( cant spell the name haha) matiz, so i went for it, and i occasionally get an engine light after a 30 minute highway run, it shows up with these faults:
ECU info obtained with Carista 4.0.6 for Android:
VIN: WVWZZZ1FZ7V035091
Engine
Part #: 03C906056EA
Component: MED9.5.10
Coding: 72 (decimal)
Fault codes:
P3078 Throttle Control: Airflow at idle too low
P0420 Catalyst System Bank-1, Efficiency Below Threshold
ABS
Part #: 1K0907379AC
Component: ESP FRON
Coding: 19170 (decimal)
[No fault codes]
Steering angle
[ECU not present]
Airbags
Part #: 1Q0959655A
Component: 45 Airbag VW8C
Coding: 13365 (decimal)
[No fault codes]
Power steering
Part #: 1K2909144L
Component: EPS_ZFLS Kl.069
Coding: [none]
[No fault codes]
Central electronics
Part #: 3C0937049AE
Component: Bordnetz-SG
Coding: A18C0F0700041000000A00320F00000000185D035C0001 (hex)
Fault codes:
01333 Door Control Module: Rear Left (J388)
Body/convenience system
Part #: 1K0959433BT
Component: KSG PQ35 G2
Coding: 88908A0001862E7F4004800D30085E0080FCA0 (hex)
[No fault codes]
Driver's door
Part #: 1Q0959701D
Component: Tuer-SG
Coding: 693 (decimal)
Fault codes:
Front passenger's door
Part #: 1Q0959702D
Component: Tuer-SG
Coding: 2408 (decimal)
Fault codes:
00121 External warning lamp/door door light front seat passenger side
Rear left door
[ECU not present]
Rear right door
Part #: 1Q0959704A
Component: Tuer-SG
Coding: 128 (decimal)
[No fault codes]
Steering wheel
Part #: 1K0953549AP
Component: Lenksäulenmodul
Coding: 11 (decimal)
[No fault codes]
Heater & air conditioning
Part #: 1Q0820047H
Component: Climatic PQ35
Coding: [none]
[No fault codes]
Parking sensors
Part #: 1Q0919283A
Component: 30 Einparkhilfe
Coding: [none]
[No fault codes]
Convertible top
Part #: 1Q0959255B
Component: Verdecksteuerger
Coding: 655362 (decimal)
Fault codes:
Radio
[ECU not present]
Instrument cluster
Part #: 1Q0920963
Component: KOMBIINSTRUMENT
Coding: 17403 (decimal)
[No fault codes]
Immobilizer
Part #: 1Q0920963
Component: IMMO
Coding: [none]
[No fault codes]
CAN network gateway
Part #: 1K0907530K
Component: J533__Gateway
Coding: 3D3F274007005001 (hex)
Fault codes:
00470 Combination comfort Databus in Single Wire
01305 Databus for Infotainment
01304 Radio
Central electronics 2
[ECU not present]
(The rear left window never worked since i baught it in november)
The boot closing aid didnt work, i baught a replacement as i thought it might get the closing aid working, but i connected the new (used) part and still nothing, i expect something is unplugged else where, but thats not the fault at hand, the reason i get the light is because of the faults:
P0420 Catalyst System Bank-1, Efficiency Below Threshold,
Ive put cata-clean through it, with shell v-power, and after a quater tank it didnt show up for a while which i was happy about, but today i did about 70 miles and it showed up as i got home, im not sure why it shows up, ive asked a few mechanic friends and they arent sure, and since 'unnecessary' travel isnt allowed i cant go to them to get it checked with their computers (i used a Carista OBDII VAG scanner for the faults, and im not sure what to do of this,
Thanks in advance,
Kac
You will have to work through the faults and replacement parts may cost more than you think, but that's why you got the car cheap. If your windows have faults your roof will not work.
Even if the roof never works, you've got yourself a bargain Golf coupe there. The engine codes don't sound too problematic to solve; the other ones less so.
