It rained today for the first time since December (we call it rain here but compared to the precipitation in the UK it was just a drop in the ocean) and I discovered a minor leak at the top of the A-pillar on the passenger side.
After a brief search I found that the leak was at the top of the drain tube (that runs down the A-pillar) where it fits into a rubber sleeve that connects the tube to the drain hole (see pic 1).
When I checked the connection between the tube and the sleeve, I found that the tube was only fixed to the sleeve at 2 opposing points on its' circumference; I could push the 2 prongs of a pair of tweezers between the tube and the sleeve (see pic 2). When you look into the sleeve at the end of the tube, you can see a shadow where the tube is not fixed to the sleeve (pic 3).
The last pic shows the fix; I wrapped some butyl tape around the join. It seems to have sealed the join but I'll see how it goes.
So, if anyone has any leaks at the top of their A-pillars, this is something you should check or have checked.
PS, I checked the drivers side for the same problem and it was completely dry.
