1 - 2 of 2 Posts
I have a 2008 Volkswagen Eos, and I recently encountered a problem with the power driver seat. I used the electric switch to recline the back of the seat all the way forward (don't ask why 😂), and it got stuck in that position. All of the other functions work, except the back reclining.
I tried to diagnose the problem by taking the switch control out and testing it with a multimeter and found that the cords going to the motor were not receiving any current while all of the other ones had 12V passing through them. I purchased a new unit, and I found the same results, I also noticed that the motor is not trying to move at all.
Any help is much appreciated! Thank you in advance!
I think you should start by studying a wiring diagram for your EOS VIN. Then when you poke around with a multimeter you will understand what you are doing and what you can expect to measure?
1 - 2 of 2 Posts
