Can’t say I’ve heard of an EOS fuse issue but on the Mk1 Tiguan there was an issue and the cure was a gold plated fuse to prevent over heating.
Mick
Hey,
I have bought VW EOS 2.0T DSG version 2 weeks back because. Its 2012 model with 43000 miles on it and the previous owner has serviced it regularly but just after 2 weeks of using it front right low beam,high beam,indicator and fog lights and in back exact same has happened but on the left side.
I took car to dealership and they are asking for 1000$ to fix it and not only that they are readily accepting that melting of fuse box is regular issue and its not related to how you use the car and also its regular issue in VW cars.
Please help me if any of you know of any campaign VW has taken to address the issue.
I also have a 2012 Volkswagen Eos and same exact problem passenger side low beam hi beam is no tail lights and no marker lights on passenger side but when I jiggle the fuse box everything lights up I'm also asking for helpHey,
They will probably tell you ABS is not flammable, but the wiring inside is! When temperatures get very high even ABS will burn to some extent. It may sound like word semantics but insurance companies try to distinguish between flammable and parts like ABS that shouldn't 'ignite'. When the rest of your car burns out there's no argument, whatever the cause.Same thing dealership wants to replace everything for $1,400 but I just spent 15000 for the car 2 months ago and I think I should get some resolution somehow because it's not a victim of normal driving it is manufacturer error
What was the part number?the new part plus installation was only $275.
