This question popped up and some saying they had gaps like MY07 or bigger. We concluded that as long as the side members are fully locked, any gap seen however ugly to look at was a common EOS 'feature'.
I can now explain this:
Each side member trim is held by seals on the outside, 3 pegs and two torx screws fixing through brackets at the rear of the trim. The trim cover is a cunning piece of ABS to remove. Towards the front are 2 white 8mm door card type pegs that run in slots in the trim and push into a hole in the side member assembly. The third peg catches you out because it's a solid fixed steel peg that also slides in a slot (in the opposite direction!) about half way along the trim capping. At the far rear end are 2 torx screws fastening through brackets that are also slotted.
Therefore, the entire length of this side member capping can be moved forwards and back once the two rear screws are slackened. To access these screws (I've marked mine in yellow) you have to drop the headlining from the front, but only as far as the center retaining bar. Unfortunately, the length once moved forwards or back either leaves a gap at the rear and closure at the front, or a big gap at the front and no gap at the rear.
My personal preference is for not much gap where the capping trim meets the 'A' pillar, and a larger gap at the rear which you don't often look at. If you have large gaps at the 'A' pillar, experiment by moving the trim cover. It may be stiff and it helps to have a bag full of the press in clips (Fleabay) just in case they break.
