Greetings and Happy 2021!
My 2013 Eos has developed a roof leak on the passenger (right) side, so I've been investigating possible causes. The symptom is that water leaks in and drips onto the outer (window-side) edge of the seat when I brake or make a left turn while driving in the rain. I'm aware of the potential issues with the clogged A-pillar drains and dry/cracked roof seals, but the drains seems to be draining, and I've Krytoxed my roof seals at least annually since I bought the car in 2016.
Instead, I'm wondering if my roof has developed a misalignment that could be causing the leak.
As I wait for the roof to close, I tend to watch the points where the roof pegs connects to the A-pillars. (I never get tired of watching the roof close, and anyway, I'm stuck there with my finger on the close switch until it's finished, so...) Late this past summer, I noticed that a small gap remained on both sides when the roof closed, and this has continued to be the case. I'm almost certain the gap was not there prior to August.
Please see my attached photo, showing the left side where the roof meets the A-pillar. What do you make of the gap? Of course I've looked at the roof from the outside and, to my eye, everything seems to be sealed/lined up.
Assuming it's supposed to line up more tightly than that, any suggestions as to the cause of the misalignment? Again, this gap is visible from the interior on both the right and left sides. More to the point, is there some straightforward way for the dealer to adjust the distance of travel so there is no gap?
While I do take a DIY approach to many things in life, I don't have access to a garage so won't be tackling any Eos roof issues myself. I have to assume the major VW dealer here knows their way around the Eos roof, but I'd like to hear from the experts on this forum about any pitfalls I might encounter.
Thanks for any experience you can share about this gap and possible causes.
Anne
Anne
