Check the dial next to the dash brightness - it may just be that they are dipped more than they need to be.
The dial in question is to be used when towing I believe, as the front of the car sits up, making the normal dipped beams too bright for oncoming traffic.
The only other person I knew had a problem had the Xenons, and eventually rejected the car. Can't quite recall who that was though.
Hey Derek - no offence, but judging by the typos, it looks like the booze has been going down very wellMaybe in Australia and the USA its darker, I am quite happry with the standard light which came on thecar ??
Merry Christmas to all, tureky etc going down well, more improtantly the booze
Derek
jeffa 1 that isha veri impolite fing to shay arbout a frellwo frorum usher sush a rathbog........lol.
Randy,I used to have the standard OEM low beams, and was not happy with the relatively dim low beam light output. I have self upgraded to 5000K HID Xenons. In order to make this work right, you need to have a Ross-Tech VAG-COM and reprogram some things...
- have low beam circuit operate operate at full voltage at all times
(you WILL have problems if you try to run HID ballasts at the
standard reduced voltage the low beam circuit puts out in DRL
mode or when the High Beams are also on)
- disable the low beam cold bulb check function
(warm check still works when headlights are turned on)
- make the fog light circuit function as DRL rather than the low circuit
(I also raised the DRL voltage to make the fog lights a little brighter
as DRLs since they are mounted lower)
The HID ballasts draw 35 Watts vs. the standard bulb 50W load, this is enough to make the low beam bulb check function happy and not get any bad bulb fault codes stored in the control module or displayed in the MFD.
The result is very satisfactory, they are about 2.5 X brighter than the OEM low beams. They still throw a legal USA low beam pattern. The amount of light and the pattern they throw out is about the same as my sister's 2008 Mini Cooper also equipped with HID low beams. This is legal to do in the United States, as long as you do 5000K or lower color temperature, can't say if headlight modifications are also allowed in other parts of the world.
Merry Christmas and a Happy New Year to all !![]()
My retrofit with original VW parts plus Kufatec harness, only bi-xenon headlights bought used, cost totally about 1600,00 Euros inclued also the headlight washers and 2 working days. With new bi-xenon headlights will be about 2200,00 Euros.Changing to Xenons would be horribly expensive but I believe someone on this site did either do it or investigated the full cost of doing it.
The holes in the bumper beneath the headlights are for headlight washers, which come as standard with factory-fit Xenons or as part of various option packages.
If you have Xenon lights fitted there are some laws that have to be complied with too, like automatic self-levelling (maybe headlight washers too, but I'm not sure).
You can buy just replacement Xenon bulbs but whilst they are brighter, from what I have read in magazines about them they are also less than perfect, as the holders you are putting them into are not made for Xenons so they get very hot. Believe they are technically illegal in the UK but don't think anyone makes much of a fuss of that!
