Hi there, new to forum and just bought a 2006 eos tdi sport and when you indicate right everything works from the outside but on the dash the battery light, fog light and boot open light flashes as well.
had battery checked and all seems good, also does it when you put hazards on because i did think it may be the stalk
any ideas guys?
cheers in advance
Almost sounds like an earthing issue
yeah, thanks pal will get garage to check it out.
anything electrical and they look blank though!
difficult finding an auto electrician round here, a one that knows what he is actually doing anyway
We have the same problem down south, I have had bad dealings with so called Auto electricians all they want to do is take your money and run, so if you find a good one don't let him get away IMHO.
Mick
IMHO I'd choose a diagnostics scan first. Even if it is an earthing problem, that will show up as a large number of 'phantom' control module faults.
