Hi Everyone! Just got my 2011 a couple of weeks ago - I might have bought the last manual transmission EOS in the U.S. - certainly in the southeast. So sad they discontinued that option in the (U.S.) 2012 models!
There isn't a whole lot of information out there about bike racks on the American EOS, so I thought I would share my experience and some pics, for anyone else that's wondering about this.
(Click for bigger images)
I got a Draw-Tite Sportframe receiver - this is rated at 200 lb tongue weight and 2000 lb towing.
http://www.etrailer.com/Trailer-Hitch/Volkswagen/Eos/2011/24824.html?vehicleid=2011208575.
For the rack I chose a Swagman XTC-2.
Some things about the install:
I had to jack up the passenger side a bit to get the receiver in place.
On my car, the passenger side bolt spacing is apparently non-standard. I couldn't put the exhaust hanger bracket bolts back into place. I called eTrailer, and they called Draw-Tite, and the spacing on the receiver is the spec'd 4 inches. I guess there's some variability between cars as to the exact placing of the exhaust brackets. I expanded the rear passenger side bolt hole by about 1/4 inch with a dremel and grinder bit to make everything fit.
http://jimandkatrin.com/images/eoshitch/bolts.jpg
The receiver pushes up the rear fairing by about 3/4 inch. It's not really noticable because it's under the car - and it might be by design to keep it from vibrating.
The main bar of the receiver touches my trunk floor - in fact it was "in the way" by about 1/8 or 1/4 inch. I couldn't push the bolt flanges flush against the frame, and had to just torque the bolts down. Again I'm chalking that up to some variability in the car.
Some of the heat shield does need to be trimmed back - the aluminum can be cut with a sturdy utility knife.
With the middle bar of the rack folded down, there's plenty of room for the top to open.
The bike closest to the car doesn't have a lot of pedal clearance, but the rack is very sturdy and I don't think it will flex enough for the pedal to hit the trunk. I'm going to put an sock over that anyway; I could bang it when putting the bike on the rack.
All in all, I'm very happy with the bike setup. The rack is sturdy and easier to deal with than the roof rack I had on my Jetta.
http://jimandkatrin.com/images/eoshitch/back.jpg
