Yesterday i discovered that both the interior drivers side and passenger side door handles were not working on my 2010 VW Eos SE. This was after a particularly cold night here in the UK (-6C) so I could not operate the windows (frozen solid) to reach the outside door handles but luckily someone was able to free me from the outside when I reached my destination - the exterior door handles do still work thankfully. From reading other posts on this forum i can see that the handles are connected to a cable which can break - but i find it improbable that both would break at the same time (or maybe I have just been unlucky - they were both working fine the night before)? There is no resistance when trying either of the interior door handles. Is there anything else I need to be looking? I ran a diagnostic via VagCom and the only thing i can see relating to the door electrics are a couple of error codes which i suspect were generated when trying to roll the windows down when the mechanism was frozen (error code also shows on passenger side door):
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2122
Coding: 0021175
Shop #: WSC 00020 790 00000
VCID: 397335A470A753D693D-806C
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Many Thanks
Coding: 0021175
1 Fault Found:
Many Thanks
