I purchased and installed the Peripheral Technology iSimple Automotive Media Gateway on my Eos. The model is PXAMG.
It is compatible with the 2006-2008 non-navigation VW OEM Factory Stereos with SAT button.
I purchased with the VW wiring adapter, PGHVW1.
I like it, here is what it does:
1. With radio in SAT mode, one presses TUNE button twice to enable selecting SAT, AUX, and iPOD modes using the CAT/FLDR button. I have Sirius and it works exactly the same as before when the PXAMG is switched to normal SAT mode.
2. Provides iPod input with dock connector that supports all iPhone 3G, all iPod Touch, iPod Nano Gen 3 and 4, and Video iPods, that have current Apple firmware. The current version charges them all including the new models that require 5 Volts. When iPod is attached here, the song and artist is displayed similar to how XM and Sirius displays on the VW radio display. The radio and steering wheel can control:
- next/previous track from steering wheel or by turning tune dial
- can go to browse mode by pressing OK on steering wheel or Preset 2 on radio and then browse by Playlist, Artist, Genre, or Composer
- use CAT FLDR or steering wheel up down buttons to move up down browse lists
- tune knob is pushed in or OK on steering wheel is pressed when you get the one on the list you want
- Preset 1 goes back one browsing type when in browse mode
- Preset 2 enters browse mode
- Preset 3 exits browse mode
- Preset 4 toggles the iPod random modes
- Preset 5 first press rewinds song next press returns to normal play
- Preset 6 first press fast forwards song next press returns to normal play
3. Provides AUX input that you can play "anything" through your stereo with. I also use this with my iPod Touch so I can direct control the iPOD touch for listening to audio books controlling directly with the iPod touch controls, this way I can go back to the exact spot in the audiobook I left off each time.
4. Could provide HD Radio but I have not tried this myself. It would be a pain to tee the antenna feeds to the HD radio module. The optional HD radio tuner sold separately, they don't now sell 'y' cable for the VW antenna wire.
Installation: The PGHVW1 is plug and play it goes in series with the square connector on the back of the radio and then has a "side" cable that plugs into the PXAMG. The PGHVW1 harness puts it in series with some of the wires that lead to the sat tuner module under the passenger seat. The PXAMG is small and all plastic so can't short anything around it out. It fits behind the radio and AC controls just fine.
The only "trick" is getting the DIP switch set to match who made your VW stereo. Panasonic made some and Delphi made some they look exactly the same from the front. The manual tells you how to figure out which kind you have. The other "trick" is that the need to push the TUNE button twice to switch the modes between SAT and iPOD. That fact is kind of hidden in the manual it threw me for a curve for a while.
It draws near zero power when the car is off, I have had for 2 months now and have had no issues with it draining the battery with the car off. Eos has sat for 2 weeks un-driven while I was on vacation after I installed this and I had no issues with battery drain on return.
I LIKE IT. For me it was worth the $130. I installed myself in 1 hour, so for me installation was free.
