Hi folks,
I'm hunting down errors in my VCDS scan, can anyone confirm if this unit is the parallel parking control unit that might be causing the fault with park assist?
Bonus points for any tips on how I can remove the connector without breaking it, looks to be wedge against the floor of the boot.
As always, any ideas appreciated.
Rob
Its a UK 2011 Eos, this is the drivers side rear in the boot.
Rob
Code:
Thursday,12,May,2022,03:51:49:40859
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4608.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWZZZ1FZBV013627 License Plate: MAY12
Mileage: 110180km-68462mi Repair Order:
Chassis Type: 1F-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 2E 42 44 46 52 56 61 62 72
VIN: WVWZZZ1FZBV013627 Mileage: 110180km-68462miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 GA HW: 03L 907 309 N
Component: R4 2,0L EDC H24 8089
Revision: 41H24--- Serial number: CVN: 07142BA5
Coding: 00190012040501080000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018GA 003002
ROD: EV_ECM20TDI01103L906018GA_VW36.rod
VCID: 6FBBD75B7714F5C34EB-803A
VINID: 9E69EAAAA056A929800431821C82A8EBA4
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 563B6008092300FD6A1106E690200092350000
Shop #: WSC 00020 790 00000
VCID: 76B5E23F08CEC40B8DD-8022
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 K HW: 7N0 907 426 K
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000000003
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 3C21301776E25E5BBB9-8068
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0046
Revision: BC011001
Coding: 42000A3B8A25F06040080080340081E443515E08412001606480C7000041
VCID: 3B23330B736C5963B23-806E
Subsystem 1 - Part No: 1Q2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 07021 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 150311 05 54 0403
Coding: 0330CD
Subsystem 3 - Part No: 1Q0 951 177 C
Component: Innenraumuebe 200 0203
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Coding: 000000
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Coding: 000000
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 B HW: 1Q0 959 655 B
Component: 0Z Airbag VW8C 0210
Revision: 92011021 Serial number: 003G2000GKR+
Coding: 0012378
VCID: 3B23330B7F6C5963B23-806E
Subsystem 1 - Serial number: 6332SRB40D5E4DA4I
Subsystem 2 - Serial number: 6342SRB40D5C4A235
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 AH HW: 5K0 953 569 A
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110208300377
Coding: 0082040000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 73B3DB2B1B3CD123AA3-8026
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 1Q0 920 975 A HW: 1Q0 920 975 A
Component: KOMBI H20 0420
Serial number: 00000000000000
Coding: 471F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 33331B2B5BBC91236A3-8066
1 Fault Found:
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Einparkhilfe: keine Kommunikation]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 176
Mileage: 110187 km
Date: 2022.05.12
Time: 02:17:50
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 230311F1000856
Coding: 355001
VCID: 313F1123A120A33318F-8064
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 110187 km
Time Indication: 0
Date: 2016.10.02
Time: 02:17:57
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DC64F4CF610EB195-803E
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 F HW: 1Q0 959 255 F
Component: Verdecksteuergeraet 0854
Revision: 0033100Q Serial number: 110560388
Coding: 0655364
2 Faults Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 176
Mileage: 110187 km
Time Indication: 0
Date: 2016.10.02
Time: 02:19:10
Freeze Frame:
Voltage: 12.70 V
Voltage: 12.50 V
Voltage: 4.90 V
Error Code: 0
00220 - Connection to Sunroof
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 176
Mileage: 110187 km
Time Indication: 0
Date: 2016.10.02
Time: 02:19:11
Freeze Frame:
Voltage: 12.70 V
Voltage: 12.50 V
Voltage: 4.90 V
Error Code: 0
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669611338
Coding: 010000
VCID: 2809FC4792FAE2FBCF1-807C
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2152
Coding: 0152247
VCID: 392F290375506B73A0F-806C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 343118375232961B739-8060
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0152502
VCID: 3A2D360F7056606BA95-806E
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2L9187095
Coding: 0100040004
VCID: 6597B573A5683F93347-8030
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: 71BFD12361A0E33358F-8024
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370004726
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1Q0 959 811 B HW: 1Q0 959 811 B
Component: Tuer-SG 004 0602
Coding: 0131216
Shop #: WSC 00020 790 1012544
VCID: 3537253359488F13447-8060
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1Q0 959 812 B HW: 1Q0 959 812 B
Coding: 0131216
VCID: 3635223F444E840B4DD-8062
End----------(Elapsed Time: 01:41, VBatt start/end: 12.5V/12.6V)-----------
