Question-Do some Eos' come witha full size spare with the jack and tools mounted in the space around the rim?
I noticed in the images Golden Eos had (the thread about the Eos falling off the transporter) there was a picture of the spare tire. The tire has a formed foam piece that holds the jack and tools. Is that in a full size tire. Mine has a "limp a long" and the jack is in a foam box in the trunk. I took the parts out and put them in a bag and placed them below the tire cover floor. You have to slide it back towards the bumper at an angle, but it will fit under there. Allows more trunk space. I copied the picture and pasted it. Not sure if it will work that way. But you can see it in the other thread.
http://www.vweosclub.com/forums/attachment.php?attachmentid=174&d=1179048723
Unless something changed for the '08 models, I believe all U.S.
spec models have a "temp" tire with tools in the styrofoam box.
I was wanting to know if the other tire was a temp. Could we get that piece to fit temp tires or is it a full size?
