I recently fitted a new standard air filter to my 2012 TDi Eos, but while looking for a replacement air filter I saw an ad for a washable K&N Air filter , which claimed good performance and mpg etc etc, is this something to be avoided or recommended ?
Boz
I have used K&N filters in all my cars for well over 20 years. Never have I had any issues with oil getting onto the MAF. During every oil change I check my filter and check the MAF.
IF you oil the wrong side of the filter or use too much oil, its possible you can run into this problem, but again, the number of people who experience this are very few compared to the number of filters on the market.
In my 500E, I had a set of K&N's in it for 15 years.
Now, don't expect large gains from a K&N, on some cars you might see 5-7 hp on other cars you might not see any performance gain. Much depends upon the stock air intake system and the stock filter. On different cars I have used these filters on, I have see from 0 hp gain up to 17 hp gain, with the latter being on a 2000 Corvette.
I have a K&N in my VR6 EOS, but along with the installation of the filter, I have removed the flapper valve inside the airbox. This valve ate up 1/3 of the total airbox volume and also draws in hot air from the engine bay. Also, the snorkel at the front of the airbox was also designed not only to draw air from the grill but to draw air from the engine bay. This engine bay opening was also sealed up. Lastly, the accordion tube that connects the MAF to the TB, is small in diameter and under hard acceleration, collapses in on itself. So to allow more airflow and a eliminate air turbulence into the TB, the accordion tube has been replaced with a larger, hard silicone tube made by ECS
Performance from a air intake is also enhanced by ECU tuning and a performance exhaust.
