I am glad to see this thread is still lively. It took me a while to get back to the items I checked and here it is:
1. Flap actuator: video evidence shows at key "on" position it moves cleanly from homogeneous to stratified and then makes two small motions closer to fully stratified at the end. I assume this is its calibration routine. So this is working normally from what I see even if it takes 2 seconds (more on that later).
2. Cam lobe: inspected all camshaft lobes and there is no obvious signs of wear or difference lobe to lobe. I did some basic measurements and all cam lobes appear to be correct.
3. PCV again: since I had to remove the valve cover I decided to change the PCV to the block-plate type. Voila, problem went away!
I checked the PCV I removed and it is operating perfectly. I could not find any leaks in the tubing or anything and was a little stumped. It is possible that during my inspections something changed, but I am highly suspect of the PCV now. After some thought I may have a possible reasoning.....
Ok, so my engine has 141K miles on it. It is not new. It probably has "more than normal" blowby. That means the PCV system has to work harder than ever to evacuate the pressure. By removing the option of allowing pressure to enter after the throttle body (that is what the block plates do) and only allow blowby into the turbo inlet, I have given the engine an easier path to evacuate crank pressure and eliminated the additional "air" that enters after the TB. I do not understand how the MAF even deals with that! I am sure when the engine was new, the qty of air post-TB (post-MAF) was not a big deal, but now I bet it is, especially when cold. I think that is why the solution worked and why this is so common as engines age, but it could be something even simpler....
My video of the actuator got me thinking.... it takes it a full two seconds to get in position when I put the key on. Normal people just turn the key all the way to crank with no delay. What position is the actuator in at first crank? Currently, I have been delaying between on and crank for 2 seconds to allow the actuator to complete its dance. I did this for over 1000 miles of driving and 200 starts and no code. So maybe, it was getting a code or two every time I didn't delay in the past and they build up until enough throw the light? That seems feasible. Could be something others may want to try.
But as of now, the car runs great when cold and does not throw a code which is all I want. I will see how long that lasts! LOL
RGAZ
